Discussion topic: Sound echo on channels
Message posted on 30 Mar 2024 12:25 PM
Hi I am experiencing echoing sound issues on numerous channels eg channel 5 channel 27 TNT sports all the sound is echoing and horrendous to listen too or watch anyone any advice as I have only had this few weeks and will just get them to take this out as it's not fit for purpose
Message posted on 30 Mar 2024 12:38 PM - last edited: 30 Mar 2024 12:38 PM
Re: Sound echo on channels
@Kaz84 Have you tried going into the puck settings menu and adjusting the sound output options?
Message posted on 30 Mar 2024 12:44 PM
Hi thank you yes I have just done this will see how long it lasts but hopefully not have to do this every time not the service i was expecting 😡
Message posted on 27 Apr 2024 05:58 PM
How do you get puck settings on
Message posted on 27 Apr 2024 06:05 PM
Press home on your remote then scroll down to the bottom to settings on the left handside onto pictures and sound 👍 hope this helps
Message posted on 27 Apr 2024 06:08 PM
