Discussion topic: Sound echo on channels
This message was authored by Kaz84 This message was authored by: Kaz84
Hi I am experiencing echoing sound issues on numerous channels eg channel 5 channel 27 TNT sports all the sound is echoing and horrendous to listen too or watch anyone any advice as I have only had this few weeks and will just get them to take this out as it's not fit for purpose
Re: Sound echo on channels
@Kaz84  Have you tried going into the puck settings menu and adjusting the sound output options?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Kaz84
Hi thank you yes I have just done this will see how long it lasts but hopefully not have to do this every time not the service i  was expecting 😡
This message was authored by Claire5kidz- This message was authored by: Claire5kidz-
How do you get puck settings on
Kaz84
Press home on your remote then scroll down to the bottom to settings on the left handside onto pictures and sound 👍 hope this helps
