11
This discussion topic has been answered Discussion topic: Sky stream start up.
This message was authored by: Allen13
What a nightmare, new technology that has more bugs than anything else. Will not start, when it does can't find channels as it has a technical issue,  what a load of rubbish,  spend 15 minutes every time to get it to work in the mornings. Before you fetch out new tech give it a thourgh testing before you stick it to customers. Sky need to get their act together. I wish I never bothered.
This message was authored by: MarkGoldsmith Answer
Re: Sky stream start up.
I suspect the issue is the strength of your Wifi network in that case.
Try connecting the puck via an ethernet cable and it may improve things. You will also need to disable the Wifi in the settings on the puck otherwise it will ignore the ethernet connection and go back to Wifi.
Sky Stream, Sky Glass Air and former Sky Broadband customer
This message was authored by: Dazzasky
What did Sky suggest when you contacted them with your issues ? @Allen13
Avatar for Allen13
Level 2 icon
Hi, first of all they said it was my 3rd party broadband supplier until I told them I have sky broadband,  then they tried to blame my download speed which is 76mg , they then said I have a faulty sky stream box which they are replacing ASAP, it is the tech in the box it is a load of scrap, if this new box is not up to scratch I told them I want to back to sky q, only time will tell, this is not a robust system.
I'd suggest checking that in the settings you have overnight power saving set to OFF and networked standby mode set to ON.
1. Go to Settings
2. Go to Start up and standby
3. Set Networked Standby Mode to ON
4. Set Overnight powersaving mode to OFF.
If you need to change these settings, once changed reboot the puck by going to
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Avatar for Allen13
Level 2 icon
Marl, many thanks I have already tried this but it still wants to go into standby mode unless you follow the on screen instructions  which please pick up your remote now , not everyone needs to touch your remote every couple of hours,crazy system.
Avatar for Allen13
Level 2 icon
Sorry MARK. Not marl.
Yes thats correct - thats the built-in power saving which you cannot control or disable.
However you mentioned you had issues when turning it on every morning anh those settings should prevent that as it ensures the puck keeps its network connection, without it it can take several mintues for the network connection to re-establish once the puck has been turned back on after being in standby for a while.
Avatar for Allen13
Level 2 icon
Mark, just had the replacement stream box and I will carry out your instructions as soon as as possible, I just hope this works for me,many thanks.
Avatar for Allen13
Level 2 icon
Mark, thank you I have followed your instructions,  if it does not work I will tell you, many thanks again.
Avatar for Allen13
Level 2 icon
Mark,just connected my new stream box keeps losing network, blue screen  appears, cannot connect to  the remote, start up number 8 , this is a load of Taiwan crap,  no offence ,any more of this and I will be telling sky stick their 2 year contract, this system is full of glitches and bugs, I have a 2024 panasonic oled tv and sky can't make it run correctly, bring back sky q. Lost all faith.
Avatar for Allen13
Level 2 icon
Mark, you have been a inspiration for me ,since connecting everything including the remote several times , it has not gone off and I don't have to touch the remote like before. I am so grateful to you  many thanks, allen. Happy new year to you and your family.
