Discussion topic: Sky stream standby mode
Message posted on 25 Aug 2024 06:13 PM
Any way to stop sky stream going into standby mode apart from shaking the remote. Its annoying
Message posted on 25 Aug 2024 07:45 PM
Re: Sky stream standby mode
@cookiemonsteruk Afraid not, it will always do it after a set duration to make sure there is someone watching.
Message posted on 23 Dec 2024 11:59 AM
Absolutely ridiculous. Sick of pausing something going away for 10 mins and coming back and its lost.
Message posted on 23 Dec 2024 02:37 PM
@sean121089 If I think I will be paused for longer than about 5 minutes I tend to make a mental note of the current position and rewind about 10 minutes. When I get back I then just FF or RW as appropriate to the correct place. It's a lot of faffing about but at least you can continue with what you were watching.
Message posted on 23 Dec 2024 03:17 PM
As above, if watching a live channel, just use rewind, Watch from Start or add to playlist and one of those should get you back if just pausing for say a fifteen minute or so.
Message posted on 23 Dec 2024 04:43 PM
@lettice You are perfectly correct with the watch from start option but personally I won't use this method for this type of situation. I find that it will often put the programme onto your continue watching rail and then, even if you can get rid of it, it reappears with every subsequent episode. BBC and ITV are particularly bad for doing this.
Message posted on 24 Dec 2024 09:27 AM
Yeah its not the end of the world but this wasn't an issue 20 years ago. They are making things worse.
Message posted on 24 Dec 2024 09:39 AM
@sean121089 very true but of course 20 years ago energy saving was not high on the priorities and governments had not required electical devices to have energy saving features built-in as they do now.
Message posted on 27 Feb 2025 10:19 PM - last edited: 27 Feb 2025 10:43 PM
Its werid, the puck is only 5v so at most it use 3 to 4 amps so same as a MXQ Android box so it uses not a lot of electric, the Sky Q box uses a lot more and that does not turn itself off, it has heatsinks in it because it use a dish and the Sky Q box gets hot, plus it uses more than 5V, it uses a PS/2 type connector plugged into it in the middle of it so proberly uses 5v and 12v, like a PC does.
So I do not see Sky Steam using the same amount of electic say as a 2KW heater that 55p a day, proberly more like 2p a day.
Sky Steam uses the same amount as a mobile phone when its charging on slow charge, that uses 5v, on fast charging it uses 12v.
And it uses as much as a Mini Console(Sega Mega Drive Mini or THEC64) uses, they use 5v too because they use ARM SoC in them so mobile tech so it can use phone chargers to power them because they do not come with a power suppy, some use 3 amps and some use 1 amp and as much as a Raspberry PI. uses.
I am not a Sky Engineer but at one time wanted to be one or a BT Engineer... 🙂
I like working things out like its a puzzle... 🙂
I was a PC Engineer and fix peoples PCs by going to there house, Windows XP was known to slow down PCs over time and clog up the PCs RAM and its start-up and had to reinstall it for the customer.
Sky Glass Air 55 inch.
Message posted on 01 Jun 2025 02:11 PM
I've had sky stream since January and have only had this problem today. My tv watching habits haven't changed so I'm wondering if there's been an update in the last week (I've been out of the country so not watched for the 7 days) causing this problem today.
I've turned off the power saving features that I can find but can't find a specific setting for standby on my sky stream puck settings.
Message posted on 01 Jun 2025 04:07 PM
@Kirsty163 wrote:I've had sky stream since January and have only had this problem today. My tv watching habits haven't changed so I'm wondering if there's been an update in the last week (I've been out of the country so not watched for the 7 days) causing this problem today.
@Kirsty163 Nothing has changed - this has always been the way with the sky streaming platform and is by design. If you pause live TV, are idle on the Home Screen or pause sky on-demand content after 10 minutes of idleness the puck will turn off unless you pick up the remote or press a button on the remote switch resets the 10 minute timer.
Message posted on 17 Jun 2025 10:11 AM
Any update on this problem , I have music playing when around my flat all day and suddenly all goes quiet, was in the shower earlier and knew what it was, but did not want the faff of getting out half shaven and naked, telly remote by big balcony window lol.
Message posted on 17 Jun 2025 11:14 AM
@mfactor111 wrote:Any update on this problem , I have music playing when around my flat all day and suddenly all goes quiet, was in the shower earlier and knew what it was, but did not want the faff of getting out half shaven and naked, telly remote by big balcony window lol.
@mfactor111 The mind boggles 😂. In answer to your question, unfortunately nothing has changed and is very unlikely to ever do so as the puck (& Glass) is designed to do this as part of the eco power saving system. I agree that it is very annoying and if nothing else it could to with a longer time limit before shutting down. My Samsung TV gives various options including "Never".
Message posted on 24 Aug 2025 10:32 PM
Hi, My sky stream puck keeps going in to energy saving mode when watching live TV. It as only started doing this in last two weeks. It,s happening once every four hours. Surely it should not do this if you are watching live TV. I can understand it should turn off if I am not watching. Most frustrating feature.
Message posted on 25 Aug 2025 12:15 AM
@kendoe47 As annoying as it is the puck is supposed to shut down after a period of inactivity. The puck has no way of knowing if you are watching or not which is the reason that a warning appears on the screen just before it shuts down telling you to pick up the remote. That is the pucks way of telling if you are there or not. Personally I find it highly annoying and should give you much more warning before it shuts down. You mention it happens after about 4 hours in my case it is much quicker than that, I would guess at less than 2 hours but have never actually timed it.
Even more annoying is when you pause a programme and when you return after 6 or 7 minutes you find the puck has shut down. It happened to me yesterday and today.
