Discussion topic: Sky stream keeps sticking on Sky logo at start up.
This message was authored by Shelley661 This message was authored by: Shelley661
We have been on Sky Stream for a while now and been working ok.  After the big storm we had in the midlands last week, the sky stream puck upstairs is now getting the following issues.
1.  Get the white flashing light, Sky logo appears then stops and get on the TV no signal. Yes we are on the correct hdmi slot on the tv.
I have also swapped the hdmi cables to see if it was that, but nope still happening.
2. have done a reset and got it working then
3. today switched it on again no signal, so pressed the button held it for about 3 secs and the picture came on.  Watching a programme and it went off after about an hour and back to no signal, pressed the button again and it came back on.
any clues at what is happening or do I have a knackered puck ?
This message was authored by Frances4 This message was authored by: Frances4
Re: Sky stream keeps sticking on Sky logo at start up.
Same problem but no solution
Still no solution
Not helpful. What am i to do please
Very disappointing
This message was authored by eyeeye This message was authored by: eyeeye
Same problem. Any solution?
Shelley661
They swapped the Puk out in the end as they said it was at fault.
The software update loop seems to be an issue for some of us
