Discussion topic: Sky stream keeps freezing or screen goes blank
This message was authored by: Rachael108
Tv keeps going blank or screen freezes and I've tried the restarting and all other prompts
Re: Sky stream keeps freezing or screen goes blank
@Rachael108  How is the puck connected to your broadband hub?  On the puck open the netflix app, go to get help, run connection test, what speed is being reported?
Avatar for Rachael108
Hi it's 138.23 mbps thank you
@Rachael108  Thats is plenty for the puck, however if connected over wifi it can suffer interference.  Are you able to try ethernet between the puck & hub, you'd need to go into the settings menu to reset the network and turn wifi off.
Broadband is in hallway and tv in living room 😕
@Rachael108  I would give Sky a call to see they are able to do.
Thank you
