Discussion topic: Sky Stream Homepage
This message was authored by: Iain+Mclean
Sky Stream Homepage
Hey, just received Sky Stream today, wow, glitchy . I was hoping for better, and I think its not right, in the home screen banner I have two "Tv Shows" noted on the banner that notes Playlist, Movies, Sport Etc,  I have,
Playlist, TV shows, TV shows, Movies, Sport, Kids Etc.
Is it supposed to be like that ? .. I've done a reset, power off etc, but still the same ..
Re: Sky Stream Homepage
@Iain+Mclean  You should be seeing double/superimposed text & images, I would go into the pucks settings menu,system management,  restes & updates select restart device.
Avatar for Iain+Mclean
Yes thanks, did all the resets etc, but I still have two "Tv Shows" in the scrolling banner, kind of annoying .. 😞
