1
This discussion topic has been answered Discussion topic: Sky stream keeps dropping signal
This message was authored by: Dawn146
The signal keeps dropping out for a few seconds. I have tried resetting on Sky and by hard reset. The problem persists.
Re: Sky stream keeps dropping signal
@Dawn146 most likely cause is a poor network connection to the puck. If using WiFi do not assume because you have a fast connection to the internet at your router that the puck must have a good connection. You can see the strength of the connection by going into the pucks Network settings. It is also sensible to measure speed the puck is getting by going intomthe Get Help menu in the Netflix app and running the Network test.
