Discussion topic: Sky stream is absolutely awful. I’m done
Message posted on 16 Jun 2025 10:08 AM
Re: Sky stream is absolutely awful. I’m done
@ALAW1 wrote:I'm having all those issues . End of this contract is end of sky
Have you informed Sky? They will assist with troubleshooting your home broadband network in order to try and improve your service.
If you still can't get it to function reliably or to a standard you deem to be worth the amount being charged, then Sky will usually allow you to leave a streaming TV contract early without penalty.
You need to contact them though and make an attempt at improving your broadband connection to your Stream puck. Sky Stream is not like Sky Q - it relies entirely on the customer providing a fast and stable enough connection. There is no in-home engineer support.
Message posted on 18 Jun 2025 01:56 PM
I'm now on bt. Connection is so much better. Price is cheaper too. Sky did try and get me to look at skyq but the price was eye watering so ditched sky and now back on bt. My only real gripe with bt is the box doesn't support Disney.
Regarding the remote control not contolling the tv, BT engineers did help. When connected to an AVR, it needs two hdmis if you want to control the tv. Single hdmi and the remote won't control the tv. I suspect this is the reason why the sky remote also wouldn't work. Surprised that sky engineers didn't suggest this in all my calls with them.
Message posted on 14 Aug 2025 09:04 PM
Absolutely agree with everything . I can't wait until in can kiss it goodbye
Message posted on 14 Aug 2025 09:49 PM
Well i last reported on here in march i think . And after connecting to the mesh ive not had a single problem with the puck . Its been fantastic .
@ALAW1 use your 31 days cooling off period.
Message posted on 15 Aug 2025 10:42 AM
The picture is good but the sound is **bleep** . When I go on Netflix etc I have to turn sound down after it's been on sky channels
Message posted on 15 Aug 2025 11:21 AM
@ALAW1 have you reportedto Sky all the issues you're apparently having, (even though the picture is good)?
Or are you just complaining without doing anything about it?
Message posted on 15 Aug 2025 11:23 AM
I've complained about loads of things that aren't working properly. And nothing every changes or gets fixed
Message posted on 15 Aug 2025 11:31 AM
Yes rang them they said it may be my internet lol
i have BT full fibre 500
Message posted on 15 Aug 2025 11:37 AM
I've had a cable running across my house for over two months because Stream decided after a year of working fine, that it couldn't work on WiFi anymore.
This despite there being absolutely nothing wrong with my WiFi, as confirmed by Sky. And also previously working well for over a year with that same WiFi.
For a year and a half, I've had football and basketball games randomly missing every single week in series links playlists.
Just awful
Have you called just the once?
Message posted on 15 Aug 2025 11:41 AM
Yes had the series link issues as well . My pick is hard wired into router .the sound sink issues went away for a while after I changed something in settings but as returned . If I turn over to a different channel and then back again it re sinks ok
Message posted on 15 Aug 2025 11:48 AM
Yes, the series links issues are incredibly frustrating and the 'super users' on here refuse to acknowledge the problem.
Sky themselves, ignore it too
Message posted on 15 Aug 2025 12:38 PM - last edited: 15 Aug 2025 12:53 PM
We almost never claim there aren't problems (because that would be silly) : what we might do is comment on the number of posts relating to a particular issue, or whether we've experienced it ourselves. Sometimes we can also say if we've had feedback from Sky.
Message posted on 15 Aug 2025 12:54 PM
@TB18 wrote:Yes, the series links issues are incredibly frustrating and the 'super users' on here refuse to acknowledge the problem.
no doubt there is a problem ........ as others have mentioned best course of action is to email viewerR@sky.uk which is the department that can investigate these issues
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
