Discussion topic: Sky stream , honest review
Re: Sky stream , honest review
Yep. Same here. The greed of this company is totally immoral. I want out but I'm so limited. I think I'll just go get a new tv with freeview and get a fire stick. Sick of the greedy companies
Given that digital terrestrial television broadcasting almost certainly has a limited future, a television with both Freeview Play and hardware support for the upcoming Freely app may be a better investment.
Thanx. I really appreciate your reply. I am still researching but I am done with (Removed) sky. I've found the right tv. Or at least I think I have. Thanx for the mention of Freely. Did not know about that
Moderator note: Removed unfounded allegations.
This message was authored by: Loue
Does everyone think that a refresh apps tab would be much better at the top of the screen rather than deep in the settings menu
This message was authored by: Padam_Padam
It needs that or the ability to fully force close any apps left running in the background. The whole server-based app hosting on Glass/Stream just doesn't function well enough without something like this. Customers shouldn't have to be turning these devices off at the wall every day just to get them to function reasonably reliably.
Not really.
All settings should in my view remain together.
I've not had any issues with Sky Stream apps and did not either with my eight years of Sky Q.
Now into my eight week of using Sky Stream.
Have not had any problems with any of the apps on Sky Stream.
Use ITVx, C4, C5 apps, along with Youtube, Apple+, Disney+, Paramount+, Spotify daily along with a lot of cloud recording/ watching  each day and linear TV live channel viewing watching across the channels in hd and hdr.
Not had one glitch with any of the apps, whether using them individually from the home or Sky Stream menus,, launching form playlist additions or from my continue watching.
Have also occasionally used BBC iPlayer, mostly for Beechgrove Garden, do not really watch  much else form BBC, also with no issue.
As well as launching apps from the Home or Sky Stream menus, often launch other apps while within apps on Stream, using the voice option.
As well as not having any glitches with apps, not had any problems with Stream at all. No lockups or any need to reboot the puck.
Im on Sky broadband Uktrafast+ (Latency 4-5ms, 523-525 Mbps download, 72-74 Mbps upload). Netflix speed test via my main wifi puck shows 290-330. Have another puck on ethernet that reports speed in the 90Mbps via Netflix speed test.
I do generally exit apps using the Sky Stream back key until it asks from the app to leave with an option, but also do use the Sky Stream remote home key to exit an app. I'm  sure that the first option may help for some customers with issues and with apps to clear up some of the cache sometimes that may cause issues.
@Loue Personally I am happy with the App refresh where it is.  In 2 years I have probably only refreshed my Apps 4 times and probably 2 of those times was not due to any issues but rather me thinking it was about time they were refreshed.  I always close the apps properly using the back button until the exit button appears of I end up back on my home screen.
Admittedly it can be tricky to find the first time you want to use it but I suspect most people will  within a few days of getting Glass/Stream go through the menus to see what options are available to them.
I use stream everyday for my playlist but everyday the playlist needs a refresh so I can watch the previous days playlist
Cheers but I've decided. Sky and I will be parting company as soon as possible. I'm out today to get new tv. Not taking stream. There are cheaper options. I'm happy to give up one or two things to save money. Hundreds of channels I never watch,  and platforms all taking the Michael and applying pressure. I'm a pensioner. I'm done with them. They're just stealing from me
This message was authored by: Jporch316
I don't think the refresh apps option has anything to do with the playlist (if that's what you are referring to)
im not even sure you can refresh the playlist .....
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
It does as it refreshes apps - sometimes I can see something on my playlist but it won't play until I refresh
Ah .... I presume you mean when you try to play something from your playlist the relevant app won't open ?
that's very odd ... it's not happened on my glass or pucks. In fact I don't think I've used the refresh apps in the two years I've been using them. I did have some issues with the 5 app the first time I signed in but a quick plug out solved that.
is it one particular app that's a problem ? It's my understanding that the refresh app settings not instant but takes several hours to complete in the background
I suspect the cause of this is because you aren't exiting the apps. What can happen on the system is if you don't exit the apps eventually the device can ran out of memory and thus won't play any shows from the apps until you reboot the puck by unplugging it for a couple of minutes.
I'd suspect your refreshing of the apps is actually in the background closing the apps and thus freeing up memory, although the rebooting method is usually quicker than waiting for the app refresh to complete.
I'd suggest regularly exiting each apps (this can be done just using the back button a couple of times when they are open, or a couple of the apps will have an exit button on their main home screen).
@Loue  As @MarkGoldsmith points out I close all my apps after each use .... including Netflix where you have to go to the "exit Netflix" icon
force of habit from working with windows PCs most of my working life
I start doing this very recently, to avoid the exact issue i mentioned above which was annoying me every couple of weeks when i couldn't watch anything via any of the apps.
