Discussion topic: Sky stream frozen
This message was authored by: Shanklin1
Sky stream frozen
My tv is stuck on itvx and nothing will move nor the remote home button
Re: Sky stream frozen
I've moved your post from the Sky Q forum as you say you have Sky Stream.
As you cannot move the remote to use a settings restart.
Try repowering your puck first, by removing or switching off the power to the puck.
Once its powered back on and your remote is still stuck, try a remote control repair:
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue
More remote control help here;
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remo...
