This discussion topic has been answered Discussion topic: Sky stream and sky glass
Message posted on 27 Aug 2024 11:13 PM
I recently purchased the sky stream I believe it was but I've just added the sky glass to my account now which is being delivered tomorrow. Just wondering what happens now? Do I send the sky box back as it's all built into the tv? Will it get taken off my bill now and replaced with the sky glass or am I going to be paying for both even though I no longer need the sky box. Thank you
Message posted on 28 Aug 2024 09:42 AM
@Caitlin726 wrote:So on my app it says I have the sky glass, whole home and sky stream. So that is right? I just plug the sky stream into a different tv not the sky glass? Thank you for you reply
Correct. Connect the puck to any other TV in your house and you can view your subscription channels on it via the same Sky interface.
The Sky Glass TV has the user interface built in so you don't need to attach anything to it.
Message posted on 28 Aug 2024 07:35 AM
Re: Sky stream and sky glass
@Caitlin726 wrote:I recently purchased the sky stream I believe it was but I've just added the sky glass to my account now which is being delivered tomorrow. Just wondering what happens now? Do I send the sky box back as it's all built into the tv? Will it get taken off my bill now and replaced with the sky glass or am I going to be paying for both even though I no longer need the sky box. Thank you
You don't purchase Sky Stream, you are loaned a Stream puck for the duration of your streaming TV contract. If you don't want to use it to get the Sky Stream 'experience' on a second TV in your home then you must return it to Sky or they will charge you a non-return fee.
If you want to use it on a second TV you will need to add the Whole Home subscription to your Sky Glass streaming TV package in order for the puck to work.
If you only want to use Sky Glass then once it's activated give Sky a call and they can send you packaging to return the puck.
Message posted on 28 Aug 2024 09:23 AM
Message posted on 28 Aug 2024 09:58 AM
Brilliant, thank you so much for you help!
Message posted on 28 Aug 2024 10:20 AM
@Caitlin726 wrote:Brilliant, thank you so much for you help!
No problem. Hope it all works for you.
