30 Aug 2023 10:22 PM
31 Aug 2023 12:02 AM
Posted by a Superuser, not a Sky employee. Find out more@DMas1 When you say it just dies do you find the batteries have gone flat? I had a remote where the batteries only lasted about 3 weeks. I phoned Sky and they replaced the remote for me.
If the remote just stops working and the batteries are OK then try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. There was a faulty batch of remotes at the end of last year and this method often worked even though it sounds an unlikely solution. Whether it will work on newer remotes I don't know but it's worth a try.
Also, if you have one available a Sky Q remote will work just fine with Glass or Stream.
31 Aug 2023 06:34 PM
31 Aug 2023 06:43 PM - last edited: 31 Aug 2023 06:50 PM
Posted by a Superuser, not a Sky employee. Find out more@DMas1 You have been busy and I'm sorry to hear you have not resolved the issue. It seems as though you need a new remote so I will escalate your post to the Community Messaging Team who will send you an online chat invitation (probably tomorrow morning). Do you have a Sky Q remote available as this will work in the meantime.
The link below explains the procedure when your post has been escalated.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Keep a look out for the colourful speech chat bubble that will appear on the bottom left of your screen when you are logged onto this forum. When the blue bubble does appear you have 48 hours to respond or it will be automatically closed. Note replies from Sky are not instant so you’ll need to regularly check the chat thread.
01 Sep 2023 08:59 AM
Posted by a Sky employeeThanks for escalating. We've sent an invite to @DMas1.
03 Sep 2023 11:22 AM
Posted by a Sky employeeWe are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
