Discussion topic: Sky puck not working
This message was authored by: Benllo
Message posted on 17 Oct 2025 05:52 AM
I have a 2 year old puck. It has always been intermittent but now hardly works at all. I keep having to reboot but it continually does not connect to WiFi, keeps dropping out, says there is a technical fault or is very laggy. When I go on diagnostics it says it's working fine. This is clearly not the case. How do I get a replacement?
This message was authored by: Jporch316
Find out more
Message posted on 17 Oct 2025 06:53 AM
Re: Sky puck not working
Hi @Benllo
@you need to contact sky for further troubleshooting
worth trying to move it in the open
try an ethernet cable and turn the WiFi off
run a network check within the Netflix app settings to see what speed you are getting
reboot your router
