This discussion topic has been answered Discussion topic: Sky arts channel not working
Message posted on 12 Oct 2025 04:08 PM
Channel been unavailable for at least 3 days. When selecting channel it freezes the remote and requires powering puck down to see anything.
Message posted on 13 Oct 2025 07:20 PM
Hi,
Found out that by updating all apps and refreshing things, it seems to have fixed the problem. Thanks again for ypur help
Message posted on 13 Oct 2025 01:26 AM
Re: Sky arts channel not working
Hi @Mike952 I have just checked on my Stream puck and SKy Arts was working correctly so it would appear to be an issue at your end.
In case it is just a software glitch try rebooting your puck by going to Settings > System Management > Resets & Updates > Restart device. It takes a couple of minutes to completely reboot and you will have a blank screen for a couple of minutes before the Sky logo appears.
Good luck.
Message posted on 13 Oct 2025 09:42 AM
Thank you for your advice. I have restarted the puck but unfortunately it has not made a difference. The problem only seems to affect trying to stream the painting programme fronted by Stephen Mangan.
Message posted on 13 Oct 2025 07:14 PM
That's a shame @Mike952 I don't know what else to suggest as the issue must be at your end as I have Portrait painter of the year in my playlist and have watched the first 2 episodes without incident.
Maybe report the problem to viewer relations at [email protected] and they will investigate in case thee is some sort of broadcast issue.
Hi,
