5
This discussion topic has been answered Discussion topic: Sky Stream use Entertainment OS
This message was authored by: spannernick1
Its here... https://www.comcasttechnologysolutions.com/syndication-suite/entertainment-os
And here... https://www.entertainmentosbaseline.com
It uses open source software but most boxes do.
I am Neurodivergent... 🙂
I am not a Sky Engineer but at one time wanted to be one or a BT Engineer... 🙂
I like working things out like its a puzzle... 🙂
I was a PC Engineer and fix peoples PCs by going to there house, Windows XP was known to slow down PCs over time and clog up the PCs RAM and its start-up and had to reinstall it for the customer.
Sky Glass Air 55 inch.
This message was authored by: MarkGoldsmith Answer
Re: Sky Stream use Entertainment OS
It's quite common for software to contain some open source libraries for common features/functionality that are generally present in most applications (e.g logging).  Typically reusing these is a way to shorten development time and cost as otherwise the software developers would need to create their own code from
scratch to cover the functionality that the library is providing.
This message was authored by: Dazzasky
Ok.
@spannernick1  You seem to be posting information that everyone who has Glass/Stream already knows, why?
Avatar for spannernick1
Level 4 icon
Sorry, I didn't know you all new about it and its open source software it uses.
The most interesting thing is not the use of Open Source code itself, but that GPL forces Comcast to list all the different hardware running on the same codebase.
