13
This discussion topic has been answered Discussion topic: Sky stream remote
This message was authored by: Brandon197
Sky stream remote
Why have I been given a smooth shiny remote with one puck and a new Matt finish with the other are both pucks the same or not like older batch? both have same model number
This message was authored by: Mister_Dalek Answer
Re: Sky stream remote
@Jporch316 wrote:
@Mister_Dalek
Yes I've got both types ....
but they are both made from the same materials
Perhaps they've started using the same shiny plastic that was used for the Q remotes on the latest batch?
Sky pucks are loaned so one could be a return🤔
This message was authored by: Jporch316
Can you post a photo of them both ? All the remotes I have had have all been identical
@Jporch316
Some Stream/Glass remotes have subtle differences as can be seen in the design of the volume buttons on these two, pinched from a couple of eBay listings...
@Mister_Dalek
@Jporch316 wrote:
@Mister_Dalek
@Mister_Dalek
The other option is one is "used" and the Matt finish has been glossed up from use ?
@Jporch316 wrote:
@Mister_Dalek
Entirely possible. It must have had a heck of a lot of use if it's fully glossed up though...
I'd be very interested to see a photo if there is a new model .......
Avatar for Brandon197
From what I've heard it's a new remote I thought the Matte one was the newest I'm new to sky
Can't really tell from the photo but it looks heavily used to me ......
It's a new remote the buttons are smoother on this model
This message was authored by: jakeyj
Tne Sky Stream remote is terrible for attracting marks. Does anyone know if there is an alternative to it?
Answered - Go to Answer
