5
Discussion topic: Sky Stream has stopped working, is anyone else having this problem?
This message was authored by Gordon18 This message was authored by: Gordon18
Sky stream has not worked today, does anyone know why? I tried to contact Sky using the virtual assistant thing but that is useless (I am being polite!) .
Gordon18
This message was authored by Gordon18 This message was authored by: Gordon18 Answer
Re: Sky Stream has stopped working, is anyone else having this problem?
Picture freezes and/or loss of sound.
After turning off and restarting they seem to be working now.
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek
Have you turned it off at the wall for a minute then powered it back on?
Is your broadband functioning correctly?
Gordon18
I will try that, but I have 3 pucks and none of them are working today.
This message was authored by Jporch316 This message was authored by: Jporch316
Also try rebooting your router by completely pulling the plug and leaving off for 10 minutes or so
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
Also in what way are they not working ?
Gordon18
