5
This discussion topic has been answered Discussion topic: Sky Stream, does anyone else miss their recorded data on Sky Q when using Sky Go ?
This message was authored by: reylee
hi
I recently moved from Sky Q to Sky Stream, and there is a feature that I miss: the ability to view "recordings" from the Sky Q box via Sky Go when connected to home wifi.
Example,  my home office has no TV so I use my Macbook connecting to Sky Go (which crashes ALOT, but thats another story). The Big Bash is on in the morning, and I used to be able to watch it from the start using the recorded info on my Sky Q box to Sky Go, but this feature is no longer available, as it appears Sky Go has no understanding of "playlists".
Does anyone else miss this function ?
Re: Sky Stream, does anyone else miss their recorded data on Sky Q when using Sky Go ?
That's correct: Go is legacy software from when Sky was an independent company, while Stream (and Glass) is a Comcast product.
There is no facility to view or add to your Sky Stream playlist or anything like that remotely or using the Sky Go app, like Sky Q does.
Its often requested on here as a feature, so far no show.
But you  never know may appear at a future date.
Would suggest emailing the Sky Go apps team, their feedback email address is on their app pages and also a feedback option within the Sky Go app under the Settings support tab.
Have you tried a search in Sky Go for the Big Bash cricket, notice there is quite a lot of it on demand on Sky Stream and Sky, maybe some of what you are looking for.
Avatar for reylee
hi thank you for the reply, I will email them.
the catch up is list a lot later and is only ever the highlights and not the full match, you also cannot see it until the live match is finished.
This message was authored by: Dazzasky
@reylee wrote:
hi
Not really
Avatar for reylee
ah good to know. thank you
Answered - Go to Answer
