5
This discussion topic has been answered Discussion topic: Sky Stream connection
This message was authored by: Starry3
Just moved over from Sky+ HD to Sky stream.  I have connected the previoius HDMI cable from SKy+HD box to the Sky Stream box.  The light is on but how do I access the programmes.
This message was authored by: lettice Answer
Re: Sky Stream connection
First thing.
It is best to use the hdmi cable that came with your Sky Stream package.
It is a high speed cable, better suited to Sky Stream output, unless your current hdmi cable mention is a high speed one.
Next;
  1. Check the cables in the back of your Sky Stream puck are connected properly.
  2. Check which HDMI port it's plugged into in the back of your TV.
  3. Make sure you're on that input/source by pressing Source or Input on your TV remote until you find it.
First thing.
Next;
This message was authored by: Nigelb1972
Use the HDMI cable that came with the puck as it's a higher specification one.
Avatar for Starry3
Thank you. What a shame Sky only provide a very short HDMI cable making it limited where sky puck can  sit!!
Avatar for Starry3
Would be better if Sky sent a longer hdmi cable!! Mine is barely long enough!
@Starry3
You can purchase a longer hdmi cable.
Just make sure it mentions it is an HDMI certified  2.1 cable.
Should not cost you more than £10
Answered - Go to Answer
