12 Mar 2023 12:46 PM
I'm waiting for my new sky stream pucks to be delivered.I currently have my set top box running through my amazon firecube 3rd gen hdmi .Will I be able to run sky steam puck through the amazon firecube.The options only give cable and satalite sky q nothing for sky stream.?
14 Mar 2023 09:14 AM
Posted by a Superuser, not a Sky employee. Find out moreI would hold off on selling it until you try the pass through - if virgins box works through it I can't see why the stream box can't
you can't install any apps on the stream box - you just get some of the major apps pre installed- it's worth keeping the fire cube just in case there's an app you use that's not on stream
12 Mar 2023 02:12 PM
Each of those is a source device: they are intended to input into the television set independently.
Are you perhaps thinking of using the Sky Go app on the Amazon device until the puck is delivered?
12 Mar 2023 02:15 PM - last edited: 12 Mar 2023 02:22 PM
Posted by a Superuser, not a Sky employee. Find out moreAh, presumably you mean the HDMI input on the third generation Cube: I'm not sure if that brings any great advantage. As far as I know you can't access the Stream UI that way, apart from HDMI-CEC functions.
14 Mar 2023 07:42 AM
Thankyou for your replies.Im not to worried if it doesn't work but I'm still interested to find out if it will.I will try it out when my pucks arrive and let you all know .
14 Mar 2023 07:43 AM
Posted by a Superuser, not a Sky employee. Find out moreTheoretically it should works as it's a pass through hdmi - be interesting to know if it does !
14 Mar 2023 07:58 AM
Posted by a Superuser, not a Sky employee. Find out moreAs @Jporch316 says, simple HDMI passthrough should work: what you won't get, I think, is any of the potential system integration possible with some other devices daisychained in that way.
14 Mar 2023 07:59 AM
It's only because I'm using all my hdmi on my tv.So atm I have my virgin 360 box running through my firecube hdmi in.Im excited to change over to sky stream but if it doesn't work on my firecube I can always get myself a firestick.Want to keep my firecube or get a firestick for apps that are not on sky stream.
14 Mar 2023 08:01 AM
Posted by a Superuser, not a Sky employee. Find out moreFirestick would still take up one of your hdmi slots just like the fire cube ...... but without the pass through
14 Mar 2023 08:05 AM
Oh yes of course it would.How silly am I.Oh well looks like I might be putting my firecube on ebay .Tbh there proberly is enough to watch on sky stream.
14 Mar 2023 08:53 AM
@hammerman1980 wrote:Oh yes of course it would.How silly am I.Oh well looks like I might be putting my firecube on ebay .Tbh there proberly is enough to watch on sky stream.
But a FireTV Cube runs the same FireTV OS as a Firestick and runs the same apps. Why would you want to swap a FireTV Cube for a Firestick?
14 Mar 2023 09:20 AM
Yes your right.I was trying to think of another way to get around it but changing to a firestick was not one of my smartest ideas.Still has to use a hdml so I've decided that if the sky stream does not work through the hdmi in on my firecube I will prioritise the sky stream and sell my firecube or get myself a hdmi splitter.
14 Mar 2023 09:24 AM
I will try it out and let you all know.Im surprised I cannot find any info out on this at all.Thankyou to everyone for your replies on this matter.
14 Mar 2023 10:33 AM
Just tried this for you using a Firecube 3rd gen. It works (almost) perfectly. I think I'm detecting the audio out of sync very slightly but I'm sure I could have solved this with a bit of tinkering somewhere along the chain of items which, in my case is puck to fire tv to LG oled to ARC to Denon amp.
14 Mar 2023 10:41 AM
Thankyou so much for trying this out for me.Thats great news.I have a similar set up to you or will have when I recieve my sky stream pucks.Sky stream,firecube 3rd gen and LG TV just minus the denon.Once again thankyou for your help in this matter.Could not find any info on this at all.So you have helped me and many others I'm sure.
