9
This discussion topic has been answered Discussion topic: Sky Stream - Remote to Puck
This message was authored by: Dougie+Divot
Does the remote need line of sight with the puck to work; the reason I ask is I'm thinking of subscribing sky stream (cancelled Sky Q 2 years ago) but have a wall mounted tv and I want to hide the puck behind the tv. Also, can I watch sky stream on iPads elswhere in the house (is there a separate app) and will it have the same functionality as watching on the tv. Many thanks.
This message was authored by: Skull+Treaty Answer
Re: Sky Stream - Remote to Puck
@Dougie+Divot wrote:
Hi @mikealanr , Thank you once again, just one more question, as you are the oracle,, does the puck have an Ethernet connection, I have full fibre into the house and prefer solid connection for stability.
Thanks Dougie+Divot
@Dougie+Divot  Yes it does, it's how I have mine connected. It supports WiFi 6 too so you'll likely get faster speeds (your broadband package dependant) via WiFi. I use a wired connection as it's plenty fast enough for my viewing needs (including UHD/HDR)
Hi @Dougie+Divot
No the remote connects via Bluetooth as well as IR functions.
More info on the remote generally: https://www.sky.com/help/articles/your-sky-glass-remote
MikeAlanR
Avatar for Dougie+Divot
Hi @mikealanr ,
many thanks, very helpful. Can I watch Stream via sky go on my iPad. Thanks
@Dougie+Divot
Yes but note that the channel line up on stream (and Go) is different than Q.
See: https://www.sky.com/help/articles/tv-channel-list-sky-glass
Also the number of devices you can uSe is different depending on your package: https://www.sky.com/help/articles/managing-devices-and-streaming-sky-go#:~:text=You%20can%20register....
MikeAlanR
Hi @mikealanr ,
Thanks Dougie+Divot
Thanks Dougie+Divot
@Skull+Treaty,
perfect, thanks for your help.
Dougie+Divot
This message was authored by: Rahul14
Hi there. Just wondering if this works ok? Is the sky puck responsive behind a tv to a remote? My plan is to place mine either behind the tv or in a cupboard where the puck will have a wired connection. But I'm just confirming if it will respond to the remote
@Rahul14
When the remote is paired via Bluetooth, it should be fine behind a TV or in a cupboard - not that I have mine situated in either of those.
