Discussion topic: Sky Stream Puck tV channels freeze
This message was authored by Jack160 This message was authored by: Jack160
TV Channels freeze when watching on our Sky Streaming puck. Have tested wifi & broadband and they are all good. Also happens on some apps such as YouTube
Re: Sky Stream Puck tV channels freeze
@Jack160  If the TV chanels are freezing then the issue is with the speed or quality of your wifi, how did you check it was good?
Did you for example open netflix, go to the Get Help section and riun a conn ection test?  What speed was reported through this test?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Jack160
I have ran the test through Netflix and it states the connection speed is 60 Mbps. This is an adequate connection speed isn't it?
@Jack160  60mbps is ample for 1 puck, what is your total broadband speed and how many users are on it?
