Discussion topic: Sky Stream Puck tV channels freeze
Message posted on 24 Nov 2024 07:52 PM
TV Channels freeze when watching on our Sky Streaming puck. Have tested wifi & broadband and they are all good. Also happens on some apps such as YouTube
Message posted on 24 Nov 2024 08:34 PM
Re: Sky Stream Puck tV channels freeze
@Jack160 If the TV chanels are freezing then the issue is with the speed or quality of your wifi, how did you check it was good?
Did you for example open netflix, go to the Get Help section and riun a conn ection test? What speed was reported through this test?
Message posted on 24 Nov 2024 09:27 PM
I have ran the test through Netflix and it states the connection speed is 60 Mbps. This is an adequate connection speed isn't it?
Message posted on 24 Nov 2024 09:34 PM
@Jack160 60mbps is ample for 1 puck, what is your total broadband speed and how many users are on it?
