This discussion topic has been answered Discussion topic: Sky Stream Puck stuck on PIN reset
Message posted on 20 Sep 2024 10:18 AM
Re: Sky Stream Puck stuck on PIN reset
Message posted on 20 Sep 2024 10:25 AM
@NotHappyAgain wrote:
@KevNewMedia how soon will this be sorted out? I am now having the exact same problem with my puck. Stuck in incorrect PIN loop. I've even changed the PIN to the same PIN it should've been in the first place only for the puck to tell me it's wrong
If you power your device off at the plug and back on again, you should be able to get around this problem. I offer our sincere apologies for the inconvenience.
Kev
Community Manager
Message posted on 20 Sep 2024 10:35 AM
Message posted on 20 Sep 2024 11:15 AM
We are also NOT HAPPY
Puck stuck on incorrect PIN /reset loop for 2 hours. Live chat not available, phone left holding on.
SORT IT OUT SKY
Message posted on 20 Sep 2024 12:45 PM
@NotHappyAgain and @Har1 When you get to the enter PIN do not enter it but switch off your puck at the power socket and then reboot it. This is the advice given by @KevNewMedia
It worked for me 😀
Message posted on 20 Sep 2024 02:36 PM
Thank you but can no longer get as far as the PIN screen. Getting stuck at the activate screen as the page needed to enter code at Sky.com is not working!
Message posted on 20 Sep 2024 06:07 PM
After all the Sky Stream puck issues & reset etc several times I eventually got through to enter pin then got stuck in a loop like others I've seen on this forum. What worked in the end was someone mentioned removing cables from the back of the puck leaving plug on. Waited 2 mins then put cables back in & it then let me enter my pin & now I'm back up & running. Good luck to the rest of you.
Message posted on 20 Sep 2024 07:25 PM - last edited: 20 Sep 2024 07:26 PM
@Jaxbran Glad it worked for you 😀
To help others who might read this thread, Sky have said all along that if you are asked to enter a PIN during the recovery procedure just ignore it and switch off your Puck at the wall socket instead. Then switch it back on again to reboot.
EDIT - I see I have already posted this earlier in the thread.
Message posted on 20 Sep 2024 07:56 PM
I'm having the exact same issue, sky has gone down reset it all and it's stuck on the incorrect pin page, I've changed it and I'm 100% putting the right pin in yet I keep being taken back to incorrect pin!! Can anyone help!
Message posted on 20 Sep 2024 08:10 PM - last edited: 20 Sep 2024 08:12 PM
@Charlotte118 See posts 50 and 54 above. Instead of entering a pin switch off your puck at the plug socket and then turn it back on again to reboot 👍
Message posted on 20 Sep 2024 08:21 PM
Message posted on 20 Sep 2024 08:26 PM
@AndyNH1 wrote:
Having lost Sky TV on my Puck since yesterday afternoon. I have followed the instructions to reset/reboot the Puck. Constantly getting stuck on PIN error despite resetting it. Very frustrating with little support and updates on when the outage will be resolved. Unable to speak to anyone. When is this going to be fixed?
@AndyNH1 read the posts above. do NOT enter a PIN ................... (see above)
Message posted on 21 Sep 2024 02:00 PM
Thank you
Pin locked and incorrect. Tried 5 times.
Then worked after unplugging wires from puck for 2 mins. Plug back in. When it asks for pin turn off at wall plug. Turn back on and works with pin numbers etc
Message posted on 21 Sep 2024 02:05 PM
@Emma298 Glad to read it sorted the issue out for you. Not entering the PIN is mentioned in the "Answer" post to this thread but it is not very prominent. I suspect this is the cause for many people still having issues.
Message posted on 21 Sep 2024 02:06 PM
Thanks for tour suggestions of a workaround. Not sure what happened but switched the Puck back on this morning and all working!
Haven't tried the other Puck but fingers crossed it'll be OK.
