This discussion topic has been answered Discussion topic: Set up puck wrong need help
Message posted on 04 Oct 2025 01:55 PM
When I first set the puck on my tv up it went on PC hdmi but its wrong I think it should be on tv
Message posted on 04 Oct 2025 02:17 PM
@GAIL.MOULTON65 wrote:When I first set the puck on my tv up it went on PC hdmi but its wrong I think it should be on tv
Can you edit the names of the hdmi channels on your tv?
or simply swap the hdmi cable to a different port on the tv ?
Message posted on 04 Oct 2025 02:18 PM
Re: Set up puck wrong need help
It doesn't make any difference, however if it's an issue why don't you swap the hdmin cable to the correct input?
Other than that it's not a Stream issue as such.
