3
This discussion topic has been answered Discussion topic: SKY Stream remote volume Up button now starts search
This message was authored by: loui11
Every time I try and put my volume up the volume key opens the search option
This message was authored by: lettice Answer
Re: SKY Stream remote volume Up button now starts search
Would suggest first trying a repairing of your remote:
On your Sky remote:
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue
More details here;
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remo...
If a repairing after a few attempts does not solve your issue, you can order a replacement remote online on the later pages on that link above
Hi @loui11
Try the following:
  3. Wait until you see the 'Your remote is now connected' message and select Continue.
If that doesn't work you will need to request a new remote as per the info here: https://www.sky.com/help/articles/remote-control-help-sky-glass-wrong-menu
MikeAlanR
On your Sky remote:
More details here;
Avatar for loui11
Thanks. I have tried this and have contacted sky.
