Discussion topic: Sky stream dosent work
This message was authored by: Daniel139
Every night at 9.30 my sky tv dosent work and im on the verg of cancellin it
Re: Sky stream dosent work
Hi @Daniel139
This would point to something locally to you. Who is your ISP? And what is your broadband speed? Stream needs 25Mbps for HD and 30Mbps for UHD. You can check the speed your puck is getting in the netflix app (open the netflix menu > scroll down to get help? > Select connection check).
It's sounds like some sort of contention happing, particularly if there is a consistent pattern to the issue.
MikeAlanR
