Discussion topic: Remote will not stay paired with puck
This message was authored by JosephineV This message was authored by: JosephineV
My remote will not stay paired with the luck for more than a day - sometimes for less than a few minutes. Problem started about a week ago.
Re-pairing is haphazard and seems distance dependent, works when holding the remote within about 3-4 feet of the puck.
Don't need to use 4-6 or 7-9 to repair, just go straight to 1-3, so it seems to have forgotten it was paired.
Remite works perfectly in unpaired mode. Changed the batteries, didn't help.
Suggestions?
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Remote will not stay paired with puck
@JosephineV The Glass and Stream remotes are extremely poor quality and cause no end of issues.
I would be inclined to request a replacement.  You can do this by calling the Customer Service team or alternatively there is a request form at the following link: Streaming TV replacement remote It will ask you sign into your My Sky app and will then populate most of the form automatically.
If my post has solved your issue please mark as an "Answer"
