Discussion topic: Remote volume
This message was authored by: DHC14
Remote volume
I've just swapped to sky I set everything up but the volume button  doesn't work
Neither will the volume on the TV remote
I don't know what I have done wrong
The bedroom one is all working fine
Can any one help
Re: Remote volume
Hi @DHC14
When you set up you should have have selected the make and model of the TV and it should have presented you with different profiles to test and choose. You can go though this again by:
Pressing and holding 7 and 9 together on your Sky remote for 3 seconds.
Pressibg and holding 1 and 3 together for 3 seconds.
Following the instructions on screen.
See: https://www.sky.com/help/articles/your-sky-glass-remote
MikeAlanR
Avatar for DHC14
Re: Remote volume
Thank you I will have a try 😊
