Discussion topic: Remote volume
Message posted on 26 May 2024 10:55 AM
							Remote volume
I've just swapped to sky I set everything up but the volume button doesn't work
Neither will the volume on the TV remote
I don't know what I have done wrong
The bedroom one is all working fine
Can any one help
Message posted on 26 May 2024 01:03 PM
							Re: Remote volume
Hi @DHC14
When you set up you should have have selected the make and model of the TV and it should have presented you with different profiles to test and choose. You can go though this again by:
Pressing and holding 7 and 9 together on your Sky remote for 3 seconds.
Pressibg and holding 1 and 3 together for 3 seconds.
Following the instructions on screen.
See: https://www.sky.com/help/articles/your-sky-glass-remote
MikeAlanR
Message posted on 27 May 2024 11:09 AM
							Re: Remote volume
Thank you I will have a try 😊
