Discussion topic: Remote control wont connect
This message was authored by: Karen7777777
My streaming remote control wont connect
This message was authored by: martswain
Re: Remote control wont connect
Is it brand new?
If so, have you checked that all the paper tags which you pull out to activate have actually come out?
You will need to remove the back to see.
Have you replaced the batteries?
Is the remote lighting up when you press buttons?
