6
This discussion topic has been answered Discussion topic: Re: Timing out setting
This message was authored by: Terry144
It times out if it is paused for a minute or two. Can this be prevented? It is very annoying.
This message was authored by: Jporch316 Answer
Hi @Terry144
@the new update currently rolling out extends the pause time to approx 25 minutes
Is your hard drive full?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Terry144
Not sure if there is a storage drive. It is only streaming service, no recording. Thanks for reply.
You originally posted in the Sky+HD forum. Your post has been moved to the correct forum.
Hi @Terry144
Avatar for Terry144
Thanks, I will try to update the settop box.
Hi @Terry144 Unfortunately you cannot force an update on the Stream puck.  The UI 3.79.0 update is current rolling out in batches and you will receive it when your turn comes around.  As already mentioned the new UI extends the pause time to 25 minutes but also does not then put the puck into standby, it simply releases the pause and your programme will just continue playing.  The benefit of this is you have the option to rewind if it unpauses.
I was updated recently and the pause function is a vast improvement.
