5
This discussion topic has been answered Discussion topic: Quick help please
This message was authored by: KCX23
Quick help please
Hey! We have just joined Sky stream and have broadband being fitted 3rd April. Our box has arrived today...do we hook up or leave until 3rd April?
This message was authored by: lettice Answer
Re: Quick help please
As above, start using it now and do a network reset from within the Sky Stream puck settings, under Network, when your new broadband becomes active.
If you don’t activate your Sky Stream puck within 21 days of delivery, your subscription and billing will start automatically anyway.
Have a read through the Sky Stream FAQ, a good starting point and flags the above.
https://www.sky.com/help/home/sky-tv/sky-tv-stream/sky-stream-faqs/articles/sky-stream-faqs
Avatar for KCX23
We currently are with VM - so have broadband with them until the switch over on the 3rd April
This message was authored by: Dazzasky
@KCX23 you can go ahead and connect now.
Avatar for KCX23
Ahh thank you! I didn't know if we had to wait for the sky bb to be fitted on the 3rd April
No, as long as you have internet then the puck will work.
Answered - Go to Answer
