Discussion topic: Problems with sky stream black screen and it keeps saying technical issues. Checked the speed all ok
Message posted on 08 Oct 2024 09:20 PM
Reset sky stream, checked speed all ok. Can watch Netflix but normal tv has a black screen
Message posted on 08 Oct 2024 09:54 PM
Re: Problems with sky stream black screen and it keeps saying technical issues. Checked the speed al
Hi , we have the same problem , first it started pixelating , it then sometimes goes black , we have to press the home button then start the program again
Message posted on 09 Oct 2024 01:44 PM
@SandraGail wrote:Reset sky stream, checked speed all ok. Can watch Netflix but normal tv has a black screen
Hi
can you check the actual speed the device is receiving ? You can do this by selecting the native Netflix app and going to settings and network check
Sky recommend a minimum of 25mb for one device .....
Message posted on 09 Oct 2024 02:13 PM
Yes checked last night , reads 44 🙋♂️☺️
