Discussion topic: Problems with sky stream black screen and it keeps saying technical issues. Checked the speed all ok
This message was authored by SandraGail This message was authored by: SandraGail
Reset sky stream, checked speed all ok. Can watch Netflix but normal tv has a black screen
This message was authored by John19642 This message was authored by: John19642
Re: Problems with sky stream black screen and it keeps saying technical issues. Checked the speed al
Hi , we have the same problem   , first it started pixelating , it then sometimes goes black , we have to press the home button then start the program again
This message was authored by Jporch316 This message was authored by: Jporch316
Hi
can you check the actual speed the device is receiving ? You can do this by selecting the native Netflix app and going to settings and network check
Sky recommend a minimum of 25mb for one device .....
43inch and 55 inch Sky Glass & sky live camera 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims.
Yes checked last night , reads 44 🙋‍♂️☺️
