133
This discussion topic has been answered Discussion topic: Problems with missing tiles and the UI lagging
This message was authored by: LazyMonkIE
Re: QS040.040.00P Issues
Are we able to force an update for those of us affected because it's getting very annoying.
Avatar for Gincap
Level 6 icon
This message was authored by: Gincap
No fully reliant on Sky pushing out the update. Should be soon 'ish' 🙄
This message was authored by: Paul+Dray
Re: Problems with missing tiles and the UI lagging
Strangely I've just turned on my Sky Stream and checked the system info as things were a bit sluggish which can happen after updates, and no I haven't got the UI version update but the build is now QS040.052.00P and platform 8.4p52s1. Few missing icon and tile images still as I guess that's still down to the UI version.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.052.00P; UI 3.268.3; Platform Version 8.4p52s1 | Sky Broadband Superfast
The fix for blank tiles as in the answered post will arrive as a UI update, that is rolling out in a phased rollout to customers.
As previously mentioned, most Sky OS fixes now come through the UI updates, rather than the build version.
Customers will be on a number of build versions at any time, depending on their Sky device and account.
Do not worry about the reference of the platform version.
This message was authored by: ollymoran
Build QS040.040.000P
Has anyone actually had the update that fixes the problems of this build? They say that they are rolling it in batches but whoever has the update did it work? Also what is the build number u need to keep an eye out for?
Oh ok. Missed seeing that info before^
Yep still waiting for that UI version fix here.
This message was authored by: MBaggers82
I force updated mine earlier and seems to have sorted this issue
This message was authored by: purpleparrotuk
@MBaggers82 The new update will come when it's your turn. Have you got the newest UI update?
This message was authored by: mancsmark
@MBaggers82 How do you force update?
Sky Stream Ultimate TV / Sky Cinema
@mancsmark Forcing an update won't give you the new UI software.
All I know is I did the force update and now it's seemless again, no blank tiles or issues
This message was authored by: MissPoppy14
Stream puck
My streaming home page sometimes you can't see the app icons eg prime, iplayer... you can still select the app but the actual icon is not loading
Re: Stream puck
@MissPoppy14
Have moved you post to this ongoing issue discussion thread.
Please read the Answered post from Sky, where a fix is currently rolling out to customers.
This message was authored by: JackieZas
Sky stream morning regular puck reboot
Ive recieved a new puck as every morning I have to reboot the puck. The new one is no different and it's connected via an ethernet cable. Initially I had 3 months with no issues. Now the morning reboot is frustrating plus later in the day I get blue blank tiles when scrolling through apps. What's e eryones advice ad I've exhausted the help sections. WiFi constantly drops out even tho the ' help' suggestions and fixes plus WiFi max haven't changed anything.
Re: Sky stream morning regular puck reboot
There's currently a bad software update on the pucks which is in the process of being rolled back. You have to wait for it be pushed to your box by Sky though - you can't force an update. This is supposed to fix the blank tile issue at least and may also help with your connection issues. Good luck!
Answered - Go to Answer
