Discussion topic: Poor sound volume on stream
Message posted on 30 Jun 2025 11:36 PM
Message posted on 01 Jul 2025 12:15 AM
Re: Poor sound volume on stream
Are you a Sky Glass owner, because this is the Sky Stream section of the forum?
If you are Sky Stream then the volume is dependant on your tv or sound bar and you program the remote to adjust it.
Message posted on 01 Jul 2025 07:15 AM
It does vary though. You can keep the volume at the same level and it is quieter on some days. To get the volume back, you seem to have to restart the puck.
Message posted on 01 Jul 2025 10:18 AM
@BarryM wrote:
need to increase volume to hear and sound quality not good
Volume is typically dependent on content, while quality is to do with the speakers available to reproduce it.
Message posted on 12 Nov 2025 07:35 AM
This worked for me. Change the Digital audio output HDMI setting to PCM Stereo. Go to Settings, Picture & sound, Sound. Finally, try restarting your Sky Stream puck as this can often resolve sound issues.
