3
This discussion topic has been answered Discussion topic: Password and login not working on Sky Stream store, despite it working elsewhere
This message was authored by: Bulls1974
Hi All,
long time customer, just moved to Stream, 2 pucks.
I can access the store, but can't access my purchased movies.
 It doesn't accept my password or login (no explanation as to which one) I have logged into my account online so the details are correct, about 6 attempts to do this all failed.
Frustration is setting in fast.
Can someone help please?
Irene
This message was authored by: lettice Answer
Re: Password and login not working on Sky Stream store, despite it working elsewhere
Have you logged into the Sky Store purchases before on Sky Stream?
Just tried Myself and I am logging in fine, so assume it's not a general customer issue.
Perhaps, try a restart of your Sky Stream puck and try again.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
@Bulls1974 wrote:
Hi All,
Irene
Can you access your Purchases on the mobile device app?
Avatar for Bulls1974
Level 3 icon
HI,
Happily the reply from @lettice sort this issue out. I needed to do it twice, once downstairs was sorted upstairs took only a few seconds.
Thanks for your help.
Irene
