Discussion topic: PIN Locked
This message was authored by: Bill+Ashcroft
PIN Locked
Tried to go into Sky Atlantic and got the message 'Your PIN has been entered incorrectly 3 times - PIN locked - Please try again in 10 minute.
I hadn't tried to enter the PIN at all previously today.
It's now an hour since I started getting the message and am still getting it.
I'm unable to change my PIN because the same message appears
This message was authored by: Hill1982
Re: PIN Locked
Hi mine is the same ave you managed to rectify it or should I ring sky !? Thanks Chris
Re: PIN Locked
Go to reset reboot in settings and it's fine after doing that ..
Re: PIN Locked
Hi @Bill+Ashcroft  I would try unplugging the puck at the wall socket for a few minutes.  When upiu plug it back in it will take a couple of minutes to reboot and yu will have a blank screen for a while until the white Sky logo apears and it wil complete the reboot after about another minute.  This clears glitches and is something I do every week or so to stop glitches accumulating.
If that doesn't work then you wil need to contact Sky for some assistance.
This message was authored by: DFY
Re: PIN Locked
Having the same issue over multiple days, unplugging the puck seems to work but it's not a complete fix as it's happened just now when trying to watch something on HBO via my playlist. Going straight to HBO has also bypassed the issue as I can't be bothered to get up & unplug.
Sky, please fix with an update as clearly there's a bug here
D
This message was authored by: SharonO1
Re: PIN Locked
It worked!! 'Answer'
