Discussion topic: Netflix will not load
This message was authored by: ERW3
The app is present but it will not load to enter details
This message was authored by: Stephen+Mourton
Re: Netflix will not load
@ERW3   Two things to try if not already.  Turn your puck off at the power switch and leave it for at least 30 seconds then plug back in.  Wait for it to reload and see if that has worked.  If not go to Settings, System management, Resets & updates, and select App refresh.  This takes a few minutes so wait for it to automatically return you to the Home Screen and again see if that helps.
