Discussion topic: Netflix problems on extra box
This message was authored by: Keith237
I along with many others have had problems getting netflix
I used to get it to work by switching of and disconnecting but this no longer works.
Because I only get problem on additional  box not on main q box so I wonder if this just fault on extra box.
Tried calling sky but they say they are aware of issue since last year.
Been vip member for 18 years so would expect a little more help from sky
Anyone got same issue
Re: Netflix problems on extra box
@Keith237  Your VIP status i;'m afraid doesn't give you any greater priority over other customers, nor does it afford you greater help from Sky.
You get the same treatment as all other customers.
This message was authored by: Jporch316
@Keith237
Do you have Q or stream ?
