6
This discussion topic has been answered Discussion topic: My5 channel issue
This message was authored by: Kayst
My5 channel issue
Can't get My5 channel loadimg on tv.
never had problem until last week .
any thoughts on why or what I can do?
This message was authored by: Mister_Dalek Answer
Re: My5 channel issue
@Kayst wrote:
I just tried that and nothing still.
Try refreshing the apps:
Settings -> System Management -> Resets & Updates -> Refresh Apps
It can take up to 24 hours to complete so in the meantime you may want to use the My5 app on your smart TV instead (if it has it.)
@Kayst
Sky Q or Sky Glass/Stream ?
Avatar for Kayst
Sky stream
Do you mean the My5 app or the actual Channel 5 live streamed channel?
Have you tried rebooting your puck? Turn it off at the wall for a minute or two and then power it back on and allow it to reboot. This can sometimes clear issues such as this.
Avatar for Kayst
Avatar for Kayst
I went into my settings of pick and did reset and now all works fine Thankyou
