Discussion topic: My luck won’t connect
This message was authored by: Nadinew92
Message posted on 25 Jul 2025 09:33 PM
My new pick won't connect to the WiFi, keeps saying somethings wrong please try again
This message was authored by: Jporch316
Find out more
Message posted on 25 Jul 2025 10:37 PM
Re: My luck won’t connect
Hi @Nadinew92
@try connecting with Ethernet cable directly to the router through the initial setup stage .... you should then be able to revert to WiFi once up and running
