Discussion topic: My home address is wrong and needs editing
This message was authored by: Mozzer1
My home address on your system is slightly wrong and is missing my village name
Re: My home address is wrong and needs editing
@Mozzer1  You'll need to cal Sky as this is a customer helps customer community.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
@Mozzer1  We're a customer helps customer forum not sky support
you need to call sky directly to get the address updated
Avatar for Mozzer1
Thanks for the brilliant advice!
