1468
This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
This message was authored by: Big+Al+43
Re: Sky stream volume
I've  noticed this too. Also the sync on the sound seems slightly out. I have 3 devices and it happens on all of them.
seems fine on catchup, so wonder if there's an issue with the live signal?
Re: Sound keeps going out of sync
@Mark39 wrote:
Originally posted in the Sky+ forum.
What was?
A similar lip sync error.
Not sure it will be the same as  this one.
It looks not be a broadcast issue, more customer TV/audio setups and recent conflicts with Sky Stream software.
This message was authored by: Mr221
Re: QS025 Lip Sync Issues
Went into settings and sounds and changed digital audio output hdmi to pass through and it's solved it.
This message was authored by: Kingy2kingy
Re: Sky puck lip sync issue
Luckily for me. A call to Sky and I changed my Sound settings on Stream puck to use PCM stereo.
For years it has been set to Auto and worked fine.
She said that it's awaiting a software update but that in the meantime, the PCM stereo setting has resolved for most customers as a workaround.
Previous to that call I had hard reset everything, including have to re-register my remotes etc via Sky Activate.
All good now so lucky I suppose.
This message was authored by: Chloe-W22
Posted by a Sky employee
Hi everyone,
Thank you for letting us know you're experiencing an issue with lip sync. I can confirm we're investigating an issue with live and on demand content being out of sync on Glass and Stream but have the right people working on it 💪🏼
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by: Paul+Dray
@Chloe-W22 wrote:
Hi everyone,
It's baffling to me as to why the in-puck audio formats audio delay has been such a frequent issue. Possibly understandable in connection with third party streaming apps updates, but not with Sky's own live and on demand content. Surely it's a case of getting as little audio latency as possible and then let the users adjust for more delay according to their different setups.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS035.013.00P | Sky Broadband Superfast
This message was authored by: Elise5
Lip sync / dubbing issues
The last 2 days the audio delay has been completely out of sync. Its driving me insane. I've tried turning off the puc, I've tried unplugging everything, I've tried all of the audio delay setting, painstakingly changing it to every single setting both on sky and on my TV and still hasn't helped. Why has it suddenly changed? It's only been last 2 days? Please someone tell me there's a fix???
This message was authored by: nmbailey
Re: Lip sync / dubbing issues
It appears to be a bug introduced in a recent software update. Go into Settings, Sound and try changing it from Auto to PCM or Pass Through
Good morning!
We have identified a workaround for issues with lipsync:
Option 1: Change the Audio Output HDMI to PCM
Option 2: Remove External Soundbar/Speakers and use the TV Audio
Chloe-W22
This message was authored by: Pukkajim
So basically for me who pays for Atmos I have to go to stereo sound to get audio to match the visuals? This isn't a workaround
@Pukkajim That is exactly what it is, a temporary workaround whilst Sky find a permanent solution.  Admittedly we will not be getting the best audio format available but surely it is better than watching with lip sync and at least you still have the UHD.
Let's hope a permanent solution is found for those suffering with the lip sync issue 🤞
If my post has solved your issue please mark as an "Answer"
Avatar for GD1
Level 16 icon
You could also try Passthrough seems to wotrk for me with puck connected direct to TV with TV connected to 7.1 Surround through Earc
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Tried this today and does look to have massively improved the lip sync. Thanks for the tip. 👍
This message was authored by: JamieB234
Re: Sky Stream Lip Sync
This is exactly the same issue we have. Got Sky Puck last year (probably around 6 month too) and no issues. But for the last 10 days it's been out of sync. Definitely sounds like there's been an update issue!
We can switch it off and restart but it gets gradually worse again, anywhere between a few minutes to a few hours.
so frustrating and not at all what I want to be paying for!
This message was authored by: sammyh98
Lip Sync issues have plagued Sky Stream since the very beginning, sometimes it gets better, but never quite goes away, other times it's just really bad!!!
However, setting your audio to Passthough has worked for us.
Passthrough, in my basic understanding, stops the Sky Stream box decoding or trying to mess with the received audio stream, it simply passes the signal through the Sky Stream Box to the next device, i.e. TV or Amp and that does the job of decoding the audio signal in the format that you have selected on that device.
Hence no lip-sync issues...
Answered - Go to Answer
