Discussion topic: Issue with Sky Stream
Message posted on 01 Jan 2025 08:36 PM
At the same time every night for the past week or so, 7pm/8pm, my Sky Stream has been buffering and not working. Some times it comes up that it's a technical fault, others it says to wait for the programme to load and then goes blank. During these times when I manage to get it to play it stops after a few minutes, or continues but there's a delay between picture and sound. I've checked my WiFi, it's fine. I've reset it in settings and the check in settings has said it looks good. Does anyone know what's going on?
Message posted on 01 Jan 2025 08:49 PM - last edited: 01 Jan 2025 08:49 PM
Re: Issue with Sky Stream
Hi @NiamhK
This would point to an issue local to you, perhaps with your broadband connection and/or suffering contention. I certainly haven't experienced any such issue. Who is your ISP? And what connection speed do you get? Sky say you need 25 Mbps for HD and 30Mbps for UHD.
Also are their any patterns whoxhay help pin point the issue? Such as you always watch the same channel at that time, or there is something else going on in your household around that time?
MikeAlanR
Message posted on 02 Jan 2025 01:02 PM
Hi,
Thank you for your reply.
I ran a speed test this morning and got 87.44 Mbps. I will run another tonight at the usual time where the connection starts to act up.
There's nothing else happening in the household around that time that could contribute to the issue.
I'll see what result the speed test tonight gives.
Message posted on 02 Jan 2025 02:30 PM
@NiamhK When checking the speed you need to know what is being received at the puck and not the speed being received at the router.
To run an accurate check on the speed at the puck go to the Netflix App (Get help > Check network). The minimum speeds recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
Message posted on 02 Jan 2025 04:37 PM
Do you have more than one puck or streaming device? Do you have other internet uesr at home who come online at this time?
Before i upgraded my broadband, my circuit (75mbps down) couldn't handle one uhd and one HD from my two pucks without picture distrubance and buffering.
