20
This discussion topic has been answered Discussion topic: Is it possible to get program reminders on sky stream puck?
This message was authored by: KevNewMedia Answer
Re: Is it possible to get program reminders on sky stream puck?
Posted by a Sky employee
Hi @smudger2468 @Old_git
You'll be happy to learn that you can now set reminders on Sky Glass or Stream.
Here's the link to read about it and for some help setting them up 🙂
Kev
Community Manager
This message was authored by: kaptain
Not on mine it isn'r
That's not true
Avatar for smudger2468
This message was authored by: smudger2468
It is possible. Reboot and it should appear.
I found out that updating the puck's system has now solved that thanks....took ne about an hour on the internet searching to find that out though
Having said that I've now got programme reminders working, it's still not that great because as far as i can tell even if you have a series on your Watch list and you set a reminder for an episode, the next time it's on you have to set the reminder again, so it doesn't work like the Series Link on the HD+ Box, so it's not much better than not having it all.....or am i missing something?
Answered - Go to Answer
