Discussion topic: I need help setting up my Sky pin
This message was authored by: Paul1521
Re: I need help setting up my Sky pin
@Paul1521  If you are trying to access restricted content on your sky puck or sky go on a mobile device connected to the same network as the puck then unless you have changed it the pin is set by default to the last four digits of the mobile number registered on your account
if you are trying to access restricted content on sky go when not on the same network as the puck follow the instructions on the link  below
https://www.sky.com/help/articles/your-pin
