2
This discussion topic has been answered Discussion topic: Help Please
This message was authored by: Monty12
Help Please
Just had sky stream install having had the old sky + HD box for years and I can't pair the Sony Bravia TV with the sky remote to control volume. Any ideas appreciated.
This message was authored by: mikealanr Answer
Re: Help Please
Hi @Monty12
What's happening when trying to set up the remote? Did you go through the process and try all the options for Sony? You may find that selecting another Sony model may work.
You can go back through set up by:
Pressing and holding 7 and 9 together on your Sky remote for 3 seconds.
Pressing and holding 1 and 3 together for 3 seconds.
Following the instructions on screen
It might be worth posting your exact TV model as someone in the community may have had the same issue. Also how old is the TV?
MikeAlanR
Re: Help Please
Hi @Monty12
MikeAlanR
Avatar for Monty12
Re: Help Please
Hi Mike,
it's me again hopefully I'm not driving you round the bend with my reply but I have been responding on my mobile, not sure you received it properly, so just in case from me an my iPad thank you. 🙏
